What AN fittings do I need?
I am doing a LS swap into a mustang and I need to know what fittings I need to do my fuel setup.I have a ls6 intake and have ordered a corvette filter/regulator. My questions are;
What fitting do I need to go from the corvette filter to a AN fitting? And what fitting do I need to go from the feed line on the ls6 rail to AN? I have researched some and see where some are more prone to leak than others so tell me which ones are good and will hold up. I will be running push lock hose to connect the two. Thanks
http://www.speedwaymotors.com/LS1-Fu...Kit,41791.html
You can get just the fittings as well for like 13 bucks.
Those looks like the older design Russell connectors in the kit... which is why the cheaper kit price. But it is everything you need for the filter. You would need to complete the kit by getting another of the quick disconnect or for the fuel rail. Not sure what you are doing on the fuel tank end.
As I said, Russell has a newer QD connector that has a better locking. They now have come out with a new connector that has the QD with a AN -6 hose end, so you can attach it directly on the hose, One less connector to buy.
Look at the online Russell cat along on there Web site.
http://www.nastyperformance.com/shop...fuel-line-kit/
Complete kit lines fittings and all you will need to hook your tank to the new motor. Or give me a call I can make anything custom you may need.
