Blew my rear end and snapped my driveshaft in 2
Alright so I was at the San Antonio raceway and first run down the track, did a nice burnout and at the launch I snapped my driveshaft in 2 pieces. So I somehow got another driveshaft put it on and ran down the track again only to blow out my rear end. It sounds like I sheered the teeth off the axel shaft or the carrier but I located a complete rear end for 75 bucks. Since the enlightenment of tax season I need a built rear end and driveshaft, any suggestions? I'm only pushing maybe 450 to the wheels
I had street tires on but I wasn't the only on breaking on the launch, what I think happened is that my rear brakes locked up from the heat and expanded the fluid to cause this in turn locking the brakes to the rotor. The drivers side rear rotor has scrapes from when we pushed the car so that is what I believe occurred. I'm not to worry since I got another stock 10 bolt for cheap and ill use that till I order my built rear end after tax season
That's crazy it snapped like that.. Lucky you were able to find another cheap 10 bolt. If you know how to rebuild them, you could rebuild that one you just got and add a few small upgrades to at least help it stay together until you get a better one.
A girdle and solid pinion spacer never hurts.
No DS loop or anything, at the track I swapped the aluminum "2 piece" I created for a steel DS one off a Firebird. To my luck it fit like charm but I was unfortunate to break my drivers side axel as that's where the noise is coming from and the brake pad seems to locked onto the rotor
