5.3 to 6.0 Swap in 04 Avalanche, Need guideance...
Old 01-21-2013, 08:22 PM
Alwhite00's Avatar
Default 5.3 to 6.0 Swap in 04 Avalanche, Need guideance...
Looking into a 6.0 swap in my 04 Avy - What year engine am I looking for? Something about a reluctor wheel change??? Will my stock ECM work or can I "plug in" a 6.0 ECM? Will my harness work? What all needs to be swapped? do I use the 6.0 intake?
Looking to make this as painless as possible and looking to get all set up before one wrench is turned.
Thx.
LK
Old 01-22-2013, 06:13 AM
LS1Tech Sponsor
psiconversion's Avatar
I would stick with mid-'07 and older engines. They will be 24x and your '04 PCM will work with the engine just fine. You will need to reflash the PCM for the 6.0. From a wiring perspective, all connections should be the same between the 2 engines.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 01-22-2013, 11:13 AM
Alwhite00's Avatar
Jon
PSI
Thanks, That's great news - Has anyone on here done this swap? just would like to know if there are any hiccups.
LK
Old 01-22-2013, 11:17 PM
LS_Junky's Avatar
everything is exactly the same you will just have to get ur pcm tuned to the 6.0. no hiccups at all really
Old 01-23-2013, 05:57 AM
mikezohsix's Avatar
could you just use the PCM out of the donor truck rather than get it reflashed?
Old 01-23-2013, 05:58 AM
LS1Tech Sponsor
VIN will be different.
Jon
PSI
__________________
Ebay Store
Old 01-23-2013, 09:56 AM
LS_Junky's Avatar
yea you can and just have a tuner remove the anti-theft off of it but then the pcm that came off of the donor truck probably came with a 4l80e transmission and ur avy is a 4l60e so you will have to get the donor computer tuned to run your 4l60e also
Old 01-23-2013, 10:12 AM
thompson's Avatar
We can set you up with a 6.0 long block that will be a direct replacement with a great warranty. This will eliminate the concern of getting the correct gen block, correct crank and cam reluctor, trying to figure out if you need first or second design ect. Our 6.0 long blocks will start at $2639 and are actually built as 370CI motors. Give us a call with any questions, we are here to help make transitions such as yours as simple as possible.
Old 01-23-2013, 11:08 AM
Alwhite00's Avatar
Have a few more questions.
Is the flywheel the same on both engines?
Would a 4L80 fit in a 1/2 ton 2WD?
Any way to visually tell a 6.0 from a 5.3 or 4.8?
So even if i had the 6.0 ECM I would need a re-flash to use it, Correct? Why would the vin matter?
So I take it 07 & newer had a different reluctor wheel?
Thanks for everything.
LK
Old 01-23-2013, 11:53 AM
gagliano7's Avatar
The 6.0 has 6.0 stamped on the block.Just have your pcm tuned for the 6.0.
Old 01-23-2013, 02:08 PM
Alwhite00's Avatar
Where is it stamped?
Thanks
LK
Old 01-23-2013, 07:38 PM
LS_Junky's Avatar
the simplest thing to do in this case is to have your pcm tuned to run the 6.0 and the 6.0 has a different flywheel so you have to use your old one and they are stamped behind the alternator and PS bracket right under the head on the block
Old 01-24-2013, 04:35 AM
Alwhite00's Avatar
Can you see it while in the vehicle? Sorry for all the questions, Just want to make sure what I am buying.
LK
Old 01-24-2013, 05:59 AM
LS1Tech Sponsor
VIN MAY matter depending on your state's emissions/inspection requirements. If you dont have any emissions/inspection requirements then as the others have said you can tune your PCM for a 6.0 and call it a day.
Regarding the size of the engine..... It is cast into the back of the block.
Jon
PSI
__________________
Ebay Store
Old 01-24-2013, 09:23 AM
LS_Junky's Avatar
not really u will have to take the accessory bracket off or drop the trans. but u can just see if the 8th digit on the VIN is "U" or "N" and itll be a 6.0 LQ4 or LQ9
Old 01-24-2013, 09:35 AM
M_O_Z's Avatar
Old 10-18-2018, 03:00 AM
Beheadin's Avatar
give me an email joedee1337@yahoo
Quick Reply: 5.3 to 6.0 Swap in 04 Avalanche, Need guideance...
