another coolant question
Old 01-22-2013, 07:29 AM
JerseyLS1TA's Avatar
Default another coolant question
So the low coolant light comes about 5 minutes after the car has been running. I'll check the level on the dipstick in the reservoir before I start it and it is completely covered and dripping so I can't get a read on if the damn thing is low or not. Any ideas as to why the dipstick would be soaked all the way to the top?
Old 01-22-2013, 07:47 AM
theMOSTWANTED's Avatar
My car does the same thing every now and again but when check my coolant its full and radiator full. I was told its the low coolant sensor that needs replacing. I hope this helps.
Old 01-23-2013, 12:11 PM
Save the manuals!
wssix99's Avatar
^maybe...
First you need to open the radiator cap (preferably with the engine cold) and see if there is coolant at the top. If so, its a bad coolant level sensor. (The sensor is installed to the radiator - not the overflow bottle.) If not, its something else...
Old 01-23-2013, 02:10 PM
Thanks guys, hopefully its just the sensor. I'll check the radiator now
Old 01-23-2013, 02:50 PM
777Shock777's Avatar
Just make sure you keep an eye on ur temp gauge. Even tho its a dummy, it'll go up when its overheating, so if you see that just pull over and let her cool
Old 01-24-2013, 02:39 PM
When you check the radiator, should you be able to see the fluid?
Old 01-24-2013, 02:42 PM
Mista Blazer's Avatar
Yes, you should most deffenitly see the coolent, it should be above the sensor but below the overflow line that runs to the resivor
Old 01-25-2013, 02:19 PM
Ok just making sure. When you fill the radiator should you have the front end up, like on ramps, to prevent air bubbles? Something my buddy told me just want to know if that's necessary.
Old 01-25-2013, 05:52 PM
LS6427's Avatar
Hell no. Just fill it. An air pocket forms on the engine side of the tstat for another reason.
Old 01-25-2013, 06:33 PM
Save the manuals!
wssix99's Avatar
^ Yea, the stock system siphons off any air that accumulates.
Quick Reply: another coolant question
