SBE 346/pt88 turbo build
Well I decided to go turbo! I have played with nitrous over the years and am sick of filling bottles. So I decided to try out the turbo world. I will give you a little run down.
Engine SBE 346 LS1
Edelbrock pro flo intake
Edelbrock pro flo rails
SFI 160lbs injectors
Versafueler
truck manifolds
custom cross over piping
tial wastegate and tial bov
dual intank walbro pumps one off hobbs switch set at 4psi
stock feed with evap line as return
aeromotive 1:1 regulator
Griffin vertical radiator
twin derale pusher fans
abs delete and line lock
2 bar map
front mount intercooler
3 inch IC piping
2.5 crossover piping
PT88 turbo
blah blah blah
So I have been working on this project for a while now and thought I would share my adventure as its to cold here to do anything else lol.
I started by pulling the motor and trans to go through the bottom end and install new rod bearings and crank bearings and also paint my dirty engine bay. Might take me awhile to download these pictures. I have been taking pictures along the way as I have been doing things to the car.
Here is a picture of last years setup.
Pulling engine
Out comes the motor and trans.
Took the engine apart. Bearings looked pretty damn good for the amount of nitrous this engine has inhaled. But I took crank over to get checked and polished and ordered rod and main bearings. Crank checked out fine so a polish was all it recieved.
Engine SBE 346 LS1
Versafueler
truck manifolds
2 bar map
3 inch IC piping
PT88 turbo
blah blah blah
Pulling engine
Yes sorry should have put that on the top. It will be ran on e85.
The internals are stock with the exception of rod bolts. The motor received new rod bearings and crank bearings. The Heads are ported 806 heads that have been on the car and seem to do very well. They will stay because of the porting and the chamber size they will do well. Compression should be right around the 9.8.1. The engine does have arp head studs and mls gaskets so that should help me get a little further. I also left the cam in there from when I was running nitrous. its a 235/239 600/598 We will see how it works might end up changing it. I belive its like 13 degrees of overlap. It might not like it that. But Im going to try.
LSA is a 112+4 , I have a tial 44 gate for it. For the boost level Im not sure yet. I am going to start out pretty light (10psi) I will add boost once I get the tune happy with that amount. I would like to run 16-18psi if I can make it Happy with that much boost.
Drive train I dont think I will have to touch? I am running a art carr th400 with a tight 3800 Neal Chance covertor, 9 inch with 3.90 pro gears and 28 inch mt's. I talked to Marty at Chance last year and he thought I had a lot to gain by sending the convertor back and loosing it up. But I think I would like to try it with this setup first. The tight convetor might work just great with the turbo? 9 inch is built nice aluminum center, 40 spline mosers, braced housing, wolfcraft anti roll bar, ect.ect.
The only thing I did was cut the radiator in. I didn't really like the way it looks if you cut the core out like some do. I also moved the wires to the fender. I was also going to move the fuse boxes but they are not hurting anything where they are so no big deal for now. My dad used to own a body shop so I called in for a favor. ( come look at something at my shop. Oh bring your paint gun. I have the beer!) so we sprayed the engine bay with base clear DuPont. Turned out nice. I installed the intercooler up front by cutting the bumper support. Then made some brackets for the bottom of the intercooler.
Now I need to install fans and trans cooler up front. I also bought a derale fan to mount on trans cooler. My idea is to run it up in front of the radiator so when it's running it will really be like three pushers.. We will see how it turns out. Pictures to come.
Getting the cooling fans mounted and wired in. Then relocate the trans cooler and install fan on trans cooler. Mount front bumper. Then finish hot side. I welded the v bands on and have a couple things to finish on hot side. Almost done with it. Should have some more pictures tomorrow for you. I will be working all night on it. Should get a lot done.. I hope...we all know how that goes haha.
Here is what I did tonight with the cooling fans and trans cooler. I installed two derale fans on the rad. I then made a braket to mount the trans cooler in between the radiato and the intercooler. I also put a fan on the trans cooler and wired it into the 2nd fan for radiator. Here are a few pictures of what it turned out like. I thought the trans cooler up there would be good because it will really act like a third fan?
Front bumper in place. Fans and trans cooler mounted and wired.
