Spring rate with LS
Old 01-22-2013, 07:36 PM
rollingmuscle's Avatar
Default Spring rate with LS
I'm rounding up more parts for my conversion. On a buying spree so It's on to shocks and springs... Anyone know what spring rate to go with?? I'm leaning to a QA1 coil over conversion, unless anyone has a better tried and tested setup. They run about $450.00 with single adjustable shocks. I have a 69 Convertible Camaro with all aluminum LS from a 2002 camaro with a 4L60E trans, Aluminum radiator, Vintage AC, Stock subframe, Tubular upper & lower control arms. I talked with QA1 and they reccomend either 400 or 450 LB spring rate. Just wondering if anyone has any ideas or suggestions.
Old 01-23-2013, 06:14 AM
oldgoat69's Avatar
Which body? I did the QA1 conversion all around.
Old 01-23-2013, 07:40 AM
Camaro, I edited my original post so It's in there now. OOOps!
Old 01-23-2013, 08:00 PM
S10xGN's Avatar
I've got Aldan 450# coilovers on my Maverick, just right!
Old 01-24-2013, 06:12 AM
oldgoat69's Avatar
I think they are about right on. Ride Tech has pretty good reference chart on their website. I used it when building my rear mounting brackets.
Old 01-24-2013, 10:18 AM
I'm leaning towards the 400# springs, was considering 350# but might be a bit too light. I think the 450s are going to be a bit heavy. I was hoping to find someone with a similar build. I have to get something to set the car on the ground, won't know if I made the right choice til I get everything together I guess. Thanks Guys. Worst case, I might be selling a set of 400 # springs some day.
Old 01-24-2013, 01:31 PM
racejunky02's Avatar
I don't know much about much but I am putting an LS3 in my 69 camaro and I ordered 400# springs yesterday. With just making my best educated guess and going with the guy from Summits' best guess we came up with 400# would be about right.
Old 01-24-2013, 07:58 PM
S10xGN's Avatar
Due to being unibody, my car's actually lighter than your Camaro. I have an RCM front clip with M-II suspension, tubular control arms, all aluminum LS (carb'ed), 200R4 auto, alum radiator, A/C, etc. QA1's recommendation is prolly OK, I like my 450#'s and wouldn't change them.
Old 01-25-2013, 05:36 PM
Thanks for the detailed Info. Good to know. I talked to a local guy about this with a hdtp 69 camaro and he took the 450s out and put 400s in. He's still got the 450s if I need them. 350s will for sure be too light. I can start out with his 450s and go from there. A conv. is heavier than a hdtp so they might be fine for me as well. Good looking Maverick by the way! That was my 1st car. Inexperienced driver and wrecked it of course...
Old 01-25-2013, 05:39 PM
If you get a chance, let me know what you think of the 400s when you get them installed. Thanks.
Old 01-30-2013, 11:48 AM
It'll be a few weeks yet but I will do.
Old 01-30-2013, 12:56 PM
krwyellowZ28's Avatar
I just ordered 450# springs for my QA1 fronts going into a full weight 1970 GTO with LS1/4L60e after talking to the guys at UMI. I placed the order with 350# fronts and the tech emailed me to be sure I was sure. He was recommending 500# - 600# fronts for a "pro-touring" car, but this is just going to be a cruiser with some new technology horse power and quality ride is important.
Quick Reply: Spring rate with LS
