injector flow rate vs kpa
Old 01-23-2013, 11:42 AM
Novaray64's Avatar
Default injector flow rate vs kpa
What is the correct way to scale injectors using hp tuners. Im running 80 lb injectors with a magnafuel boost reference FPR and put 80 across the flow rate vs kpa table, Is this correct?
Old 01-23-2013, 03:26 PM
ZL1Killa's Avatar
that sounds correct.
what is your BASE fuel pressure with the FPR removed set at? reason I ask is if the injector is rated 80# @ 43.5psi; and your BASE fuel pressure at your FPR with the manifold reference removed is 58psi; your IFR is incorrect.
BASE FPR pressure w/ NO manifold hookup = xx psi
Injector 80# rated fuel psi xxx psi
if both are equal, then yes, 80# is what you put across the IFR table.
if one is 58psi and one is 43.5psi; then you will multiply 80# by 1.1547 and put that number in the IFR table across the entire table.
*square root of 58/43.5 = 1.1547; flow difference from 43.5psi to 58psi.
Another note is if you are running 18psi BOOST, then you will want to check your fuel pumps maximum pressure; as most are rated up to 70psi I think. So you will want to scale back your FPR pressure and scale your IFR accordingly...all depends on boost you are running and your fuel pump max psi.
Old 01-24-2013, 02:53 AM
Novaray64's Avatar
Injectors are rated a 43.5 and thats what pressure im running so 80s across the IFR table should work. Thank you for the help
Is there a benefit to using one of the injector flow rate calculators and scaling the IFR or is this just for a fixed fuel pressure?
Old 01-24-2013, 09:58 AM
wait4me's Avatar
The scaling of the injector flow rate table is only if you have a fixed pressure system. It is what emulates what a boost reference is doing in a way..
80 across is fine.
Quick Reply: injector flow rate vs kpa
