Turbo 5.3 fuel pump
Turbo 5.3 fuel pump
I got a stock 5.3 in an s10. It has a gt42r turbo. I'm running truck intake with car 60lb injector. Has a tu1 cam and patriot dual springs and ti retainers. I would like to run boost at 15psi or a little more. I need help with the fuel system. Do I run billet rails or stay with stock?
I was going with a -10 feed to a reg split to each rail and to -8 to the fuel cell. Will this work or is there a better way.?
What fuel pump should I get and what reg and is there anything else I should know.
