lumbar support - air pump add pic show inside of lumbar unit
Old 01-24-2013, 08:15 AM
vikingramair's Avatar
Default lumbar support - air pump add pic show inside of lumbar unit
Hi,
Need some help from you,
Does the air pump working on batt power or do i need to switch the key to ignition pos?
Nothing happends when i try to use the lumbar, i can hear the click from all relays but no sound from the pump( there should be some or?)
I have converted my TA from standard seat to Lumbar seats. Trying to fix this now.
Old 01-24-2013, 09:38 AM
Ungrounded Moderator
WhiteBird00's Avatar
The power seats (including lumbar) are powered at all times (unswitched battery connection).
Old 01-24-2013, 10:12 AM
Thank you! This helps to narrow down the trouble shooting for tomorrow..
Old 02-06-2013, 04:52 AM
I opened up my lumbar unit to see what was wrong with it. This is how my unit looked. I bought the seats last year upholstered and very nice, noticed the under carriage was corroded as hell. I took the carriage from my origin seats (standard ones) and swapped. After installation I noticed my lumbar doesn’t work, well this was my finding....
I made a search on ebay and fins a unit exactly as mine, it came from a OLDS Aurora ( not sure of what year )
Attached Thumbnails lumbar support - air pump add pic show inside of lumbar unit-inside-lumbar-module.jpg   lumbar support - air pump add pic show inside of lumbar unit-inside-lumbar-module-1.jpg   lumbar support - air pump add pic show inside of lumbar unit-new-used-unit.jpg
Quick Reply: lumbar support - air pump add pic show inside of lumbar unit
