New suspension adj. now road noise
Old 01-24-2013, 10:34 AM
Suprfast's Avatar
Default New suspension adj. now road noise
I installed all adj suspension and now I have terrible road noise. Anybody else experience this.
Old 01-24-2013, 10:50 AM
lees02WS6's Avatar
Yes. Especially if you have rod ends.
Old 01-24-2013, 11:12 AM
sscamaroburn02's Avatar
Get louder exhaust and you won't hear it. lol just kidding. yeah if you got rod ends it's more noticeable.
Old 01-24-2013, 11:25 AM
Suprfast's Avatar
Thanks. It's worse than I thought
Old 01-24-2013, 11:35 AM
handles better though.
Old 01-24-2013, 11:48 AM
z28bryan's Avatar
And you're suprised? Yeah.. that's what happens when you substitute poly or rod ends for the stock rubber bushings.
What exactly did you install specifically?
Old 01-24-2013, 12:32 PM
justin hover's Avatar
What is "all adj. suspension"? everything?
Old 01-24-2013, 12:58 PM
vikingramair's Avatar
Yes, please specify ! I have rod end on every suspension pice, from upper/ lower A arms to panhard rod. Rock hard set up with Koni and BMR springs + sfc and strano swaybars f+r.......it is noisy but when it comes to handle turns, all it´s forgiven..
Old 01-24-2013, 08:08 PM
Suprfast's Avatar
Spohn all adj. pan hard bar lca, torque arm. All adj. it handles wonderful. Just noisy
Old 01-24-2013, 09:04 PM
lethal bird's Avatar
You learn to get use to it. I've been riding with rod ended everything for about a year now and I don't even notice it anymore.
Old 01-24-2013, 11:54 PM
99Bluz28's Avatar
Make sure all jam-nuts are as tight as possible, and all mount bolts are torqued to spec..
Old 01-25-2013, 05:07 AM
Only problem I had with my little suspension was a alittle driveline vibration from the adj. torque arm. Adjusted it and it's a nice setup now...but no noise though.
Old 01-27-2013, 10:34 PM
99Bluz28's Avatar
Most, if not all the noise is coming from the LCAs, the PHB transfers very little to no noise. I'd get a set of UMI poly bushing control arm ends to replace the rod ends mounting to the body.
http://www.umiperformance.com/catalo...roducts_id=262
Old 01-28-2013, 10:48 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
This is why I try to steer people away from rod ends unless they truly know what they're getting into. Also, adjustable lowers aren't necessary unless you're looking to go with an aftermarket rearend (sometimes holes are a little off) or a taller tire to center the wheel well.
What parts do you have installed?
- Kevin
PS: I agree. The lower control arms will transfer the most noise next to the torque arm. All road noises and gear whine will find their way into your ears. haha
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 02-01-2013, 11:40 PM
quiddity's Avatar
i just finished the install of sphoon adjustable tq arm with the rod end up front and i must say im going to have to get used to the noice was not aware of how much noice it makes from power transfer, no load , load i guess im going to have to check all the bolts make sure everything is still snug
Quick Reply: New suspension adj. now road noise
