abs question
abs question
If I buy a rearend without abs/tcs for my 4ch car, will the abs still work for the front breaks or will it be completely gone? not worried about tcs, but would like to keep abs.
ABS and traction control are both controlled by the same module. If you lose one, you lose them both. I'm not sure if you can get away with using an ABS harness from a non-tcs car and run just the one sensor in the pumpkin and get away with it. Someone else may be able to comment on that.
