Rod end seal question
Old 01-26-2013, 08:33 AM
SuperStock99's Avatar
Default Rod end seal question
If I have QA1 3/4" rod ends is this the correct size for the seals?
http://www.summitracing.com/parts/sit-ws7500/overview/
I'm assuming that it's measured by the inside diameter right? That's as close as I've found.
Thanks.
Old 01-26-2013, 12:35 PM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
Those are the correct ones. I use those on my car and have had good results.
Old 01-26-2013, 01:17 PM
Thanks alot man, you're actually the same person that gave me the idea to get them when I was looking through some old threads. I just wanted to make sure I had the right size, good looking out.
Quick Reply: Rod end seal question
