2008 4.8 truck engine into 1959 chevy apache with nova subframe 68-74
2008 4.8 truck engine with stock pan is sitting on the crossmember and need to drop down 3/4 go get bolts threw motor mounts. I got the D.D. mounts that mount right up to the clam style motor mount. Is there a good oil pan for this swap or do i need to cut down the crossmember? Thanks for the help.
LS1Tech Sponsor
CTS-V pan works. We sell the kit for $330. Check out the link below to see it....
http://secure.ultracart.com/catalog/PSI/OIL-PAN-KITS/
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
If you do a search on LS1tech.com or google for cts-v oil pan the thread with various dimensions will come up for GM/Aftermarket oil pans. Hope that helps.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
