4l60e controller for a carb'd ls 69 truck
whats the cheapest controller you can get for a 4l60e...i have a carb'd ls1 69 truck running off a msd 6010 box...thanks.
Or you can take the 94-95 vintage 16197427 PCM from the C/K trucks & SUV's and the S10 & Astro and modify the bin to make it a stand alone transmission controller. Moates file server has data files on what is needed to do this.
LS1Tech Sponsor
We sell the TCI Transmission controller kit. Check it out.
http://secure.ultracart.com/catalog/.../ACC-1034.html
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
Jon
PSI
Jon
PSI
LS1Tech Sponsor
YES.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Are there any issues at all with TCI setup? Just based on fact that it looks like a FAST rich-lean setup turns me off. I had to send mine dual O2 setup back to FAST 4 times within 3 yrs. finally threw it out after using for maybe 10 runs. Biggest waste of $ and time
These are less expensive, but not sure if it has all features you want/need:
http://www.magnashift.com/magnashift_controllers.html
I got the TCM806 for my 4t65ehd but I havnt installed it yet, but these controllers came recommended to me by a very good transmission builder that has been using them for a long time.
QUOTE=psiconversion;17097525]We sell the TCI Transmission controller kit. Check it out.
Jon
PSI[/QUOTE]
will i need a tps or will it run off my tach output on my msd 6010 box with the tci trans controller?
Jon
PSI[/QUOTE]
LS1Tech Sponsor
Yes, it needs a TPS signal to operate correctly.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
