Where to buy 93-97 v6 rear springs? (95.4lb/inch) Part Number?
Old 01-28-2013, 08:31 AM
QIK E's Avatar
Default Where to buy 93-97 v6 rear springs? (95.4lb/inch) Part Number?
I'm looking to buy some v6 rear springs with the softer spring rate. Can I buy these new anywhere?
All the autoparts stores have "variable rate" listed in the specs when I try to find them in the stores. Can anyone tell me a specific part number to look up?
Old 01-28-2013, 10:22 AM
z28bryan's Avatar
Does adding softer than typical stock rear springs actually help with your launch? Assuming that's what you are buying them for.
Old 01-28-2013, 11:17 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
A car setup for drag racing will typically NOT have a soft rear spring. There is a common misconception out there that you want the car to squat down. If properly set up, this will not be the case.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 01-28-2013, 04:02 PM
QIK E's Avatar
Does anyone know where I can pick up a set new?
Quick Reply: Where to buy 93-97 v6 rear springs? (95.4lb/inch) Part Number?
