About to Spray ??'s
About to Spray ??'s
So I'm just about to start spraying my 02 z28. Mods are in the sig. I still need to look at my injector duty cycle and see what I'm at. I'm currently running a Walbro 255lph pump and the bosch 36lb/hr injectors which are 44lb/hr @58 psi.
I want to run a 125-150 wet shot on my car and I'm wondering if I will have enough fuel? Also when you pull timing on hptuners what specific areas of the table would I need to pull 6 degrees from? Any information would help since I'm new to nitrous.
here is a good rule of thumb. stock pump is good to about 450whp, 255 by itself is good for around 550 and a 255pump with hot wire is good for around 650whp.
are you planning on running a wet or dry shot. ?
when i hot wire fuel pumps i just run a decent gauge wire straight from the battery to the fuel pump. then you run that wire to a relay and use the original fuel pump wire to activate the relay. then hook the relay to your fuel pump, it should get better current instead of it running through all that thin wire. a quick google search will bring up a million write ups and diagrams
