Road Racing Road Course | Autocross
Autocross With a drag setup
Old 01-28-2013, 10:50 PM
black and pink z28's Avatar
Default Autocross With a drag setup
Ok guys i want to try autoss it will probably be just be one Avent i have two camaro one is a 98 z is has strange coilovers up front double adjustable strange shocks on the rear s60 4.30 gear with spool no front sway bar umi suspension including drag bar will this work?
The second camaro is a 96 5.3 swap auto 3600 stall 4.10 gear stock suspension would this one butter I don't really want to change much on either 1 of them just because there's nowhere to autocross close I have to drag strips witha in a 100 miles of me so drag racing as my thing
Old 01-30-2013, 11:10 AM
Anyone? ???
Old 01-30-2013, 05:30 PM
mountainbiker2's Avatar
Take the one that drives like a MANUAL. If you like Autocross, then you can change your setup.
Steve A.
Old 01-30-2013, 05:31 PM
JD_AMG's Avatar
Use the car with the stock suspension, its will be WAY easier to drive and control and Id bet put down way better times. You will have a blast, and Id bet get hooked on it
Also FYI you can set up your car to handle and ride very well while also still being able to launch ok, but it wont be with drag parts...
Old 01-30-2013, 08:33 PM
Thanks guys ill take the 5.3 car then
there is a Optima battery ultimate Street Car Challenge in Des Moines Iowa at the goodguys car show i got to hang out and navigate for 1 of the drivers at the Sandhills open road challenge and Arnold Nebraska last year thought I would go and race with them this year one time
Old 02-20-2013, 07:11 PM
gsnickets's Avatar
yeah a spool wont get you very far on the course.
Old 02-21-2013, 11:30 PM
k_cash1432's Avatar
Hastings has a pretty nice road course its not much further than kearney.
Old 02-22-2013, 11:27 AM
thunderstruck507's Avatar
Grab a front sway bar (even stock is better than none) to add when you do runs.
Old 02-23-2013, 07:30 AM
OffspringZ28's Avatar
I can't imagine a spool would be any fun on an autox course. You can probably leave the auto in first and be ok. I have a 6 speed but can usually do a course without leaving first.
Old 02-24-2013, 01:35 AM
Latch's Avatar
My car has a stock stall and I do autocrosses in first gear no problem. With a 3600 stall you might want to put it in second, otherwise you're gonna be roasting the tires and sliding all over the place.
Should be fun though.
Old 03-01-2013, 01:18 AM
js2fst's Avatar
South of Omaha has both so check out 1320
S ice cream and drag race all night then road race the next day
Old 03-02-2013, 01:36 PM
Hardrvin's Avatar
Agree with the others, stock suspension and no spool will do you the best.
Quick Reply: Autocross With a drag setup
