Rear end for LS-1
To add to what cbrodine said, you will need the tire height and RPM you want at a given speed. The best thing to do is figure out what wheels and tires you are going to run, your driving style and purpose, then throw it all in a gear calculator and determine what works best for your needs. If you are going for cross country cruises the ratio will differ from a street / strip drag car which will differ from an autocross car which will differ from a T-Bucket... you get the idea.
Summit is one place that has a gear calculator that allows you to chose what you have and solve for what you don't.
