Mobil 1 oil EP with Lucas heavy duty oil Stabilizer
I own a 2000 Camaro Z28 with a LS1 engine, I recently changed my oil and been using Mobile 1. 5-30. But this time I used 1 quart of Lucas heavy duty oil stabilizer, I added 4 quarts of mobile 1 and 1 quart of the Lucas will this hurt my motor in anyway I heard it helps the motor in different ways. Thanks
LS1Tech Administrator
Received 1,483 Likes
Personally, I would not use it.
Some people like this stuff, but I see no need for this additive.
Thanks for your replys, Im going to change it pretty soon. and stay away from this stuff. also is it ok to use the Synthetic oil in the LS1 with it having high miles? I hear not to use synthetic in older engines ?
You should be fine by running synthetic. Most people on here do including myself. I have always heard to stay away from royal purple. Do a search on here and there are tons of oil threads.
Synthetic is a better lubricant, and will find it's way through places that conventional oil may not have, and/or clean sludge away from areas that the conventional oil may not have. The end result is that sometimes engines with old, weeping gaskets will begin to weep a little more when switching to synthetic. That's about the only issue I could ever see developing from a switch to synthetic in an old engine.
I've used Mobil 1 10W-30 in my LS6 for over 98K miles w/o any problems. I used Mobil 1 10W-30 in my L98 Corvette for 261K miles w/o problems although that engine did burn a quart of oil every 5K miles at the end. You shouldn't have any problems running Mobil 1 5-30 in your LS1.
Just keep the Lucas oil stabilizer out of whatever you use.
The only time I have ever used the Lucas Oil Synth. Oil Stabilizer was when a friend of mine had some engine noise issues that did not sound serious but did not sound right. I put some in till his next oil change, It got rid of the "odd noise" then had him switch to a different oil and weight now there are no issues at all. I doubt that it would really hurt your engine but if you are using a full synth. oil that should really be all you need for everyday driving. The only additive I am currently using is that ZMax micro lubricant that does not "Add" (Because it is absorbed) to your oil level. I don't like mixing two different "Oil Based" products together very much.
Lucas increases the viscosity of the oil making it thicker. This creates an increase in oil pressure, which as said before will agitate worn seals. Pistons and bearings run on such small space tolerances and need constant lubrication in these tight spots, Lucas will decrease the ability of the oil to get in between metals. Just something to keep in mind when selecting additives and oil weights. Synthetics will dissipate heat and undergo much less thermal breakdown and sludging. All LS motors should use Synthetics especially if running at higher RPMS.
