3.8L 10 bolt the same as 5.7 10 bolt?
Old 01-30-2013, 02:45 PM
rielcrazy's Avatar
Default 3.8L 10 bolt the same as 5.7 10 bolt?
Hey I have a 2000 5.7 with 4 channel that needs a new rear. Only one I can find from a jy is a 3 channel with 3.42's from a 3.8L.
I know I can convert the 3 channel rear to 4 channel by using my parts from my rear but the jy is telling me that the 3.8 rear is a direct fit for the 5.7. Sounds probable but wanted to confirm with you guys.
Also did the 3.8L auto's have an option for the 3.42's??? I didn't realize they did thought most autos were 308's. If it's 3.42 then it should have the thin ring gear correct?(series 2 i think always mix them up). Also he says it has posi did the 3.8L's have the torsion rear in 99' like the 5.7's?
Thanks!
Old 01-30-2013, 03:05 PM
transamtom's Avatar
Any V6 with the option code Y87 came with either an M5 or A4 and 3.42's with posi.
I have one as my DD.
Old 01-30-2013, 04:10 PM
rielcrazy's Avatar
Cool thanks learn something new everyday
Anyone know if it will fit in the 5.7?
Old 01-30-2013, 08:27 PM
Spartan7's Avatar
The housings are the same. The only difference is the carrier. Most V6's were open diffs.
Old 01-30-2013, 08:48 PM
transamtom's Avatar
Not a Y87 with 3.42's all were posi's.
Old 01-31-2013, 10:37 AM
rielcrazy's Avatar
So is that a yes? lol I suppose if it has the posi carrier like mentioned above it should work right?
Old 01-31-2013, 10:51 AM
84redta's Avatar
V6/V8 makes no difference, they interchange, so just pop the top, confirm insides look good, count the teeth if you like to confirm 3.42, and posi, and buy the rear.
Old 01-31-2013, 10:52 AM
rielcrazy's Avatar
Thank you sir you are a gentleman and a schoolbus errr scholar.
Quick Reply: 3.8L 10 bolt the same as 5.7 10 bolt?
