Hypertech Max Energy Programmer #32500
Category: Engine - Power Adders
Price: $225
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): IL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
All software chordes are wrapped new with the CD, I never even tried that stuff out, I just plugged it in uploaded the tune without making any adjustments besides what I wanted my RPM Redline to be, Tire size blah blah blah and off I went....
Here are the Vehicles it can be used on....
•2001-2004 BUICK REGAL GS Supercharged and Non-supercharged 3.8L V6
•1998-2002 CHEVROLET CAMARO 5.7L V8
•2000-2002 CHEVROLET CAMARO 3.8L V6
•1997-2004 CHEVROLET CORVETTE 5.7L V8 (incl. Z06)
•2001-2005 CHEVROLET IMPALA Supercharged and Non-supercharged 3.8L V6
•2001-2005 CHEVROLET MONTE CARLO Supercharged and Non-supercharged 3.8L V6
•1998-2002 PONTIAC FIREBIRD 5.7L V8
•2000-2002 PONTIAC FIREBIRD 3.8L V6
And Here is what it does...
Shift Firmness 25%, 50%, 75%, & 100%
Shift Point Adjustment 1-2 shiftp. -6 to +6 MPH, 2-3 shiftp. -12 to +12 MPH, 3-4 shiftp. -18 to +18 MPH,
Speedometer Odometer Correction For Gears 2.73 & 4.10
Speedometer Odometer Correction For Tire Sizes 24-30 inches 1/4 inch increments
Top Speed Limiter 81, 87, 93, 99, 106, 112, 118, 124, 130, 149, 168, 186, 255 MPH
Rev Limit 5500 to 7200 RPM in 100 RPM increments
DTCs Read and Clear
Return Back To Stock
Internet Updateable
Gas Vehicles:
Higher compression ratio engines and engines with superchargers or turbo chargers were designed to use only premium octane, so only one (1) Power Tuning program for premium octane is provided. But, if your car or truck came from the factory capable of using more economical regular octane, then two (2) optimized tuning programs are provided: one for premium, and the other for regular. In most cases, Hypertech's exclusive Power Tuning for regular octane provides excellent power gains, almost as much power as premium octane. If you are using premium octane, and you want all-out, maximum power, then select premium octane Power Tuning.
We recommend premium octane tuning for vehicles using E-85 fuel. The improved engine tuning will increase the part-throttle efficiency and wide-open throttle performance compared to the factory tuning.
Speedometer Calibrator:
If you've installed tires that are larger or smaller than original equipment tires, or if you have installed a ring and pinion gear set with a different rear gear ratio, the Max Energy allows you to re-program for correct speedometer and odometer readings, as well as correct part-throttle shifting. The vehicle's computer calculates your vehicle's speed based on the diameter of the stock tires. If you've installed taller or shorter tires, or changed the rear gear ratio, the vehicle's computer doesn't know how fast your vehicle is going. As a result, the automatic transmission may not shift correctly and the speedometer readings will not be accurate (as required by law).
Top-Speed Limiter:
Automobile manufacturers limit a vehicle's top-speed to match the speed rating of the factory-installed tires. If you have installed tires that have a different speed rating, the Max Energy allows you to raise or lower the vehicle's top-speed limiter to match the speed rating of the newly installed tires. A tire's speed rating for maximum safe speed under perfect conditions is marked on its sidewall. Always obey all traffic laws when driving and only use this feature for off-highway competition in sanctioned events.
Automatic Transmission Adjustments:
Shift Firmness:
Increase shift firmness to maximize performance or when towing, to reduce clutch slippage and transmission oil temperatures. That means longer transmission life. However, this feature must not be used If you have installed an aftermarket shift kit.
Shift Points:
The Max Energy allows you to raise or lower the shift points in 100 RPM increments for maximum performance, quicker acceleration, and better 1/4-mile times. With the Max Energy Power Programmer, you have the ability to customize the shift points for every gear. Optimizing each shift point can definitely improve performance.
RPM "Rev" Limiter:
In today's vehicles, the onboard computer controls maximum engine rpm. The stock computer is programmed to shut down the engine when it reaches its redline. But if you have modified your vehicle to increase its high-speed performance, more rpm means more power. When you shift gears with the stock rpm limit, the engine falls back to below the peak of its horsepower curve. When you extend the engine's rpm range with the Max Energy Power Programmer, your engine has more power available after gear changes. By adjusting the maximum rpm to keep the engine in the "sweet spot" of its power curve, you can increase the average horsepower that accelerates the vehicle.
Cooling Fan "On/Off" Temperatures:
The Max Energy allows you to adjust the "on/off" temperatures of your vehicle's electric cooling fans to match a lower temperature thermostat, such as a Hypertech PowerStat. A low-temperature thermostat produces a cooler, denser intake charge, is less likely to detonate under heavy loads and allows the engine to make more power.
Read & Clear Diagnostic Trouble Codes(DTCs):
If you get a "check engine" light or "service needed" message, the Max Energy will allow you to read the code and gives you the ability to clear the code and turn the "check engine" light off. You can then make the necessary repairs to prevent the light from coming back on.
Return To Stock Or Change Option Settings:
Hypertech's Max Energy downloads and saves the stock tuning program, then uploads your customized Power Tuning program. Before taking your vehicle into a dealership for service, always return the vehicle's computer back to the factory programming. Once you have the vehicle back from the dealership, reinstall the Max Energy Power Programming as before. The Max Energy can only be used on one (1) vehicle at a time, so if you sell your vehicle or want to use it on a friend's vehicle, simply return your vehicle to the stock tuning program and you may then use the programmer on another vehicle that is covered in the same part number.
Internet Updateable:
The Max Energy Power Programmer comes with a USB cable and a CD containing software to enable quick updates over the internet. If your vehicle has a new calibration not available when your Max Energy Power Programmer was manufactured, it is possible that you will see a "Cal not found" message on the Max Energy screen. If this occurs, you can simply update your Max Energy with the correct new calibration via the internet. Simply connect the Max Energy (using the provided USB cord) to your computer and go to Hypertech.com. Then click on the Support button to get update downloads. You can also get the update downloads using the CD which also contains an installation video and a printable version of the instruction manual.
