Parts I'm Looking For
Here is a parts list of what I'm looking for. I'm located in Virginia..Closer the better..
1. I'm looking for a Camshaft that's 112-113 LSA and the lift size doesn't require to fly cut the pistons..
2. Driveshaft loop/ Aftermarket TQ Arm
3. 10 spoke SS Wheels
4. 243 heads stock or ported/polished
5. 12 bolt/S60/9" with 373-411 gears.
Got a DS safety loop.. Slightly bent because I pulled into a damn entrance at a bad angle.. Ran it for several thousand miles afterward with no issues. I think it is a BMR, hammertone black. You might be able to bend it back perfect, not sure. I never had an issue so didn't even pull it off.
60$ shipped
Also have a set of ported/milled 317s if interested, same thing as a ported 243.. And they work good.
60$ shipped
