Converter help?
Old 02-02-2013, 03:02 PM
6togo's Avatar
Default Converter help?
Trying to figure out how to size a converter for my build i was thinking a 4000 stall was what i needed based on my reading but not sure a 3600 would not be fine. Here is what i have LS1 11.1 comp 235/23X 62X/62X 111+2 cam 3.90 or 4.10 gears mostly street driven hopefully high 400's whp
Old 02-02-2013, 04:13 PM
justin hover's Avatar
Either one really...I like your first thought though
Old 02-02-2013, 05:35 PM
Circle-D's Avatar
Our 245mm 5C would rock in that setup, the cam would love it. But might be a bit aggressive if you rarely go to the track. So really depends on usage. If you can fill out an Ask Chris form I would be happy to help you select the perfect stall for you. Link is in sig...
Chris
Old 02-02-2013, 06:56 PM
6togo's Avatar
Form sent!
Old 02-02-2013, 07:01 PM
lemons12's Avatar
Go 4000, you won't regret that.. You might regret a 3600.
Old 02-05-2013, 06:40 PM
prokilllsx's Avatar
Depends on who makes the stall and how streetable you need it. For the track, ideally, you want it around 200 rpm over wherever you make peak torque. I would expect that to be around a 4,800 for your cam. Just a guess though. A dyno sheet would tell you what would net you the best times.
Old 02-06-2013, 07:42 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
6TOGO. I sent you a pm response.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Quick Reply: Converter help?
