TSP PRC heads on LS3/Nitrous setup?
Looking at the TSP PRC's proprietary casting.
currently running a 232/242;.617/.615; 113lsa , can anyone suggest a CC size on the heads that will give me optimal compression for Nitrous and not have PTV issues?
also, the 255's or 260's ?
im also curious to hear thoughts on the ls7 small bore setup on spray
Hey Dave the Small bore Ls7 will be better on stroker Ls3 setups IMHO.
If you want a good head cncd for spray I'd call WCCH first then AI second.
Fwiw I have 65cc chambers with 12-1 compression on the cam in my sig.
I say an 11.5 compression will be good for spray there's really no "set" rule for lack of better terms.
But as always you should always measure before install bud cause you can never be too careful.
LS1Tech Premium Sponsor
litle88,
I believe he's discussing aftermarket casting ls3 cylinder heads and I promise you there are no ported stock casting LS3 heads that compare to the PRC aftermarket casting cylinder heads.
The aftermarket casting heads allow us to provide better p/v from a 13 degree valve angle, better valve locations thanks to a all new casting & relocated spring pockets thanks to the new casting design.
For example the 260cc head flows near 380cfm while still having a smaller than stock GM runner size!
The LS7s are awesome on a ls3, but keep in mind with the ls7 heads & intake the motor will rev & peak like a LS7 engine. It moves your power band up a good bit!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
