99 WS6 Gauges, odometer Help
Old 02-02-2013, 09:33 PM
NascarTA's Avatar
Default 99 WS6 Gauges, odometer Help
Hello I have a low mileage 99 WS6. I wanted to put a custom background on my gauges, but I wanted to use a used cluster. I then found out there is no way of adjusting the odmeter. That way I can keep the original. I thought that the main ECU held the odometer info. How do they adjust the odometer when you buy a new factory replacement cluster. Do I have to get it done at a dealer? Any help would be appreciated. Thanks in advance.
Old 02-03-2013, 12:09 PM
Save the manuals!
wssix99's Avatar
Yes, you need to go to a specialist to get this done and may even have some legal paperwork to do. (Depends on your state.)
Why not just replace the face and keep your original? It's just an overlay that peels off.
Old 02-04-2013, 10:18 AM
Atrus_SS's Avatar
Anyone know where the odometer reading is stored?
There's the large circuit board that controls the entire cluster (on the right):
And then there's the smaller "control board" for the LCD:
Which one stores the odometer data?
Old 02-06-2013, 09:13 PM
NascarTA's Avatar
Originally Posted by wssix99
,Why not just replace the face and keep your original? It's just an overlay that peels off.
With my luck I would mess up the originals and kill the value of my 30th
Old 02-06-2013, 10:23 PM
Save the manuals!
wssix99's Avatar
Its really hard to screw up if you follow the directions. It's a hell of a lot easier than what you did to take the pictures above!
The needles just pull off the shafts and the face peels away. All you need to do is go through the procedure to index the needles so you can put them back at the correct orientation.
I did the same and put my old face back in the box the new one came. (In case its the difference of my car being worth $5K or $150K someday. lol)
Old 02-15-2013, 04:15 PM
NascarTA's Avatar
Default Cluster face change?
Those picture aren't of mine. Someone else posted them. I have never taken it apart. Just don't want to mess up the original. Thanks for the input. Has anyone that has changed their cluster face damaged theirs.
Lee
Old 02-15-2013, 09:39 PM
Save the manuals!
wssix99's Avatar
If you are still nervous, I will sell you my original gauge face if you screw yours up.
Having the white gauge face is so nice, I can't imagine ever using the original.
Old 02-17-2013, 03:23 PM
NascarTA's Avatar
Thanks for the offer
Quick Reply: 99 WS6 Gauges, odometer Help
