Ls1 g body
Old 02-03-2013, 09:23 AM
sbf
sbf's Avatar
Default Ls1 g body
Has anybody put a corvette 5.7 into a buick regal or g body using all the corvette accessories
Old 02-03-2013, 07:49 PM
jlcustomz's Avatar
I have an ls1 swap I did in 02' using a 99 f-body engine, but moving the ps pump down & the alt up to similar to the vette, Did cut & rebox the frame behind the idler arm & notch the crossmember for the ac, which I later changed to a sanden with a brp mount kit later.Sanden 508 has slightly more clearance than factory pump. other than frame mods for ac, you're good to go.
Used the ls1 fans with stock upgrade radiator & hand picked hoses from parts store that I was able to trim & fit.
Just to mention , there is someone here with a 2nd gen firebird(similar frame) that said he was able to use the vette pan with proper engine placement.
Quick Reply: Ls1 g body
