Help with my Vega swap sh*t storm
I was almost ready to install my LS1 and just had that feeling.. So I tried to spin it by hand and it wouldn't budge. I pulled the heads and the cylinders were full of a rust slurry..
So, I have a MSD 6LS, Edelbrock Victor Jr, Holley 750, H3 pan and a 230/224 .575/.563 111 lsa cam and PRC .650 lift springs. The 241s seem to be ok and the cam is still fine. Pistons may be salvageable but there is no way .005 is gonna clean up the sleeves in the cylinders. So, here's my question. If you had the option, would you..
Q
A. Buy another short block
B. Resleeve the current block
C. Buy an LQ4/9 and say the hell with an aluminum block.
I will be rebuilding all 3 options with new rings and bearings etc.
Also, if I buy a 6.0, will this cam work well or is it gonna get lost in the extra cubes?
And because I know everyone loves pictures..
That's one of the nicer cylinders..
Here's the nasty..
Q
Here's the nasty..
I would have the machine shop look at that block and see if it is salvageable first before I bought another one. If you do have to go with another one I would say forget the aluminum block they are just not worth the extra cash and get a LQ4/9
Q
Here's the nasty..
Q
Here's the nasty..
My vote is pick up an iron block, they can be had dirt cheap.
That's what I'm doing now. I'm dropping all the pistons and trying a home to see what I can get to clean up. Then if it's still pitted I'll see what the machine shop says.
