first camaro problems
hey guys, i just saved a stock 98 t-top camaro for $1500. the body is near perfect. problem is the motor knocks a bit on cold starts, and it sounds like it's a bit starved for air in 1st gear, maybe need new intake manifold? once it gets going though it sounds fine.
wanna add more power to it also, because this motor will go in my 91 s10 and i'll be getting a LS1 down the road
any suggestions guys?
thanks, will do. i went ahead and put in new plugs and wires today also. i was thinking about adding a bit more power to it. what do you suggest besides a cold air intake, intake manifold, and catback exhaust?
LS1s are well known for piston slap especially on cold starts. Eventually your wrist pins will crawl their way out and make a nasty gouge in the side of your cylinder wall which will then require you to sleeve it. This is what happens in my case. I would be counting down the days until you need a rebuild man. Steal on the car though! Is it stick?
