can 98 heads...
can 98 heads...
have the combustion chambers increased from 66.67 to like 70?
my heads are already ARE Stage 2 heads...is this possible?
or should I jess sell these heads...get 6.0 heads and go from there?
To the best of my knowledge there is no way to enlarge you combustin chamber for lower compression. You can mill heads to raise compression, but I cant see how you could un mill them. If you want to keep your heads get some low comp pistons.
So I guess that enlarging the bowls is possible, perhaps only to a certain degree.
