O ring heads and not use ls9 gaskets? or use ls9 gaskets?
What do you guys think would be best, o ring the heads and use a copper gasket? Or use the ls9 head gaskets? I'm going for 1000rwhp with an S88 and 390. The heads are 317's btw.
Closed ex-Sponsor Account
I have personally ran 25 PSI with LS9s on stock decked heads and standard ARP head studs. This is with E85 and no intercooler. 285+ Degree IATs. You should be just fine with just the gaskets.
Zach
Zach
Hke built engine, iron block, tfs cnc heads, ls9 gaskets,and arp studs. 25psi borgwarner 80mm and 15* timing, maybe 7 1/4 passes over 150mph at just under 3330lbs. Tons of street pulls. Engine been going hard for 3 years, no issues to speak of, the new turbo will put the 4 bolt block to the test
