Help me pick a converter.. K5 lq4 38" tires
I was running a 4 speed, but I'm swapping over to a TH400. My setup is as follows:
Lq4, 228R cam, 112lsa, mild port work, truck intake, 42# injectors
4.10 gears
38" tire
I was going with a 220-2400 converter, I want a decent launch rpm, but I also drive the truck on the street alot. Before at 55 mph I was at about 2300RPM in 4th.
Also, my research thus far shows I can use my stock 6.0/4l80 flexplate with a standard th350/400 converter, so long as I use the spacer... Correct?
Thanks guys..
4.10 gears
38" tire
Thanks guys..
LS1Tech Sponsor
K5383, Give me a call as you are only 45 mins from me and come on up.I willshow you what we do and we will make a recomendation for you.
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
