Pontiac GTO 2004-2006 The Modern Goat
What are your best cam only times at the strip
Old 02-04-2013, 01:35 PM
Dr.Goat's Avatar
Default What are your best cam only times at the strip
Title pretty much says it all. I haven't been to the strip since I bought my car. I am running a torquer v2, shorties, catless mids, magnaflow catback, k&n. Just curious on your times and I have kdw's. I do, have a 125 shot now, but really just lookin for those cam only times!
Old 02-04-2013, 03:39 PM
Dyno Junkie's Avatar
Ls1
11.79
ls3
11.19
Old 02-04-2013, 06:06 PM
6PntHo's Avatar
I went 12.4
Old 02-04-2013, 06:27 PM
Blackpanther99's Avatar
Just a cam swap on these Goats wakes them up real good.
Old 02-04-2013, 07:03 PM
svede1212's Avatar
I've been 12.34 @ 114 cam only LS1 with pretty poor 60' times. That's with a M6 and don't compare sticks with autos. Autos tend to get lower ETs but with slower traps mostly because they launch so much easier.
Old 02-05-2013, 11:35 AM
Dr.Goat's Avatar
Ok, those are some good times! Geez 11.7 that is great time. With radials or street tires? Ya, i don't really compare auto's and manuals, but these are some times I was hoping to achieve! I will post results when I go down to Indy this summer. Now if i get some Micky T's street radials, can i get to the 11's?
Old 02-05-2013, 11:46 AM
Dr.Goat's Avatar
Agreed, I feel like that is what the car wants!
Old 02-05-2013, 04:33 PM
LS1 11.79
Mickey Thompson 245/40/18
4.1:1 diff gears
4,100rpm converter
228 228 .588 .588 113 Speed Inc/Comp Cam
FAST 90
RAMJET OTRCAI
1 5/8" > 2" > 3" tri y extractors
3" cats into twin 2 1/2" system
Old 02-05-2013, 09:01 PM
chriswildermuth's Avatar
11.4@120 ls7s cam.
Old 02-07-2013, 10:47 AM
ptero's Avatar
Back in '07; on 17" Nittos no less. I've posted this slip a bunch of times... I just noticed I was car #101, I was the first car in the gate that evening. Rearing to go!
Old 02-07-2013, 09:34 PM
Canada's Avatar
11.71 with just bolt ons...stock cam.
Old 02-08-2013, 06:03 AM
I'm guessing that would be a very light car?
Old 02-10-2013, 07:39 AM
Dr.Goat's Avatar
Thank you for your mod lists showing what you did to reach those times. I have a set of 18 inch wheels on the car right now. I was looking at getting those mickey T street radials. Seems like it is possible to hit 11's after these tires are on. Do you think I should upgrade my axles? I saw a pair of geforce axles that I was into, that has anti wheel hop. Also what mounts and bushings are you guys running to get ride of all that drive-train slop the car has stock?
Old 02-10-2013, 08:26 PM
Your car is just a beast man. Goat runs real strong now.
Old 02-10-2013, 08:29 PM
I would really look into the axle upgrade, will help you at the drag strip, specially if you ever go bigger on power
Old 02-11-2013, 12:30 AM
Upgrade when it breaks. I have done at least 20 mid-low 10sec passes with stock suspension. At least 50 passes with a 1.6 or better, all with an untouched t-56.
Old 02-11-2013, 02:39 AM
gconnoyer's Avatar
11.97 @ 117.5 with a garbage 2.0 60' and 2000DA...and a 6 spd.
Old 02-11-2013, 06:02 AM
My best time in the Monaro is 11.199, this is using the original 2001 axles and tail shaft and 2003 warranty replacement 4L60E gearbox.
In both our cars most of the rear suspension bushes have been replaced with Nolathane.
The auto Monaro uses Tein adjustable suspension and the HVS GTO has Eibach and Koni red with the rear adjusted to about 80% firm.
Old 02-11-2013, 03:14 PM
svede1212's Avatar
Axles ya but drive stubs no. Replacing a stub is just removing the axles bolts and pulling it out. . . Replacing a broken stub is pulling apart the diff. Most all of the stock ones are twisted and a fair number snapped. Just a PITA preventive.
Old 02-11-2013, 05:44 PM
Mine were straight last time I checked a few months ago.
Quick Reply: What are your best cam only times at the strip
