F-Body LS1 E-Fan Amperage
Old 02-04-2013, 03:12 PM
67Firebird455's Avatar
Default F-Body LS1 E-Fan Amperage
I cannot find a straight answer as to what these things pull (at 100%) TOGETHER at start up and running. I'm looking at the Derale electric fan controller and just want it to trigger (with either a large relay directly connected to battery, or twin relays, one to each fan, also connected directly to battery) both fans at 100% when temperature reaches X, and turns both off when temp reaches Y.
Beuler?
Old 02-04-2013, 05:20 PM
Chocolate Apocalypse's Avatar
This might help:
http://www.s-10crewcab.net/HenryJ/fans/fans.html
Old 02-04-2013, 05:25 PM
Thanks. I had seen that but constant amperage was measured for BOTH im guessing. Big variation in startup vs constant.
Old 02-05-2013, 11:38 AM
flame's Avatar
They use 3 relays in the factory setup to have a high and low speed. The relays share a common 40 amp fuse. Not sure they ever go from stopped to high in this form though.
Quick Reply: F-Body LS1 E-Fan Amperage
