Turbo 400 or 'glide?
I have a stock bottom end LS1 with an A4 that has seen better days. Car weighs around 3300 in race trim with driver. Right now, it has a 224 cam, and spray. Runs 11.20 on nuts, 10.60 with a lot of excuses on spray (slipping trans). It should go much lower in the 10's with the trans issue sorted. I will be going boost at some point, just not sure if this season or next winter, so i'd like to have a good base to build off. Any pros/cons? Car isn't ever driven on the street, so keep that in mind.
I would probably use a TH400 in that combo. Not a huge torque monster so the 3 speed will probably work better.
A Glide would work fine though, it will need a bit looser converter to make up for the lack of ratio at launch.
LS1Tech Sponsor
400!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
