Opti Limits
Old 02-04-2013, 06:52 PM
TAEnvy's Avatar
Default Opti Limits
Hey guys I was thinking hypothetically, if someone was building a standing mile car and was looking to go over 200mph and well over 1k hp would it be possible to do it with the opti?
As in, is there a limit at which you can only spin an opti so high or send only such a strong spark through it without it imploding at a substantially higher rate then we see on more mildly nodded setups.
I'm not askin if it would be smart to retain it, only if there is a service limit to the opti which could be loosely correlated to a hp figure.
Old 02-04-2013, 07:14 PM
9-Second Club
Ed Wright's Avatar
My experience a has shown they don't like a lot of RPM. Over 7500 I had issues with the rotor slinging blades. After I addressed that I had optical sensor failures, with evidence of contact with the trigger wheel. I would use a crank trigger, and put a distributor in the back.
Old 02-04-2013, 09:01 PM
fex77k's Avatar
I didn't even have to spin to 7000 to kill rotors. Had to move over to a distributor setup for the strip.
Old 02-04-2013, 09:07 PM
96capricemgr's Avatar
Jeff Green's car is well over 1000hp last I heard he was balancing rotors himself and running stock optis. Running a stock pcm too though so only turning 7200
Old 02-04-2013, 09:17 PM
9-Second Club
Ed Wright's Avatar
The rotors are an easy fix. MSD rotors should be OK to at least 7000. They didn't exist when I still had one. Large as that rotor, the tip of that blade is really moving at ten grand. LOL
Old 02-05-2013, 07:33 AM
quik95lt1's Avatar
what he said^ my opti lived for 4 years behind my 7krpm 355......it ate the rotor 3 times on my 383 spinning well north of 7000 before i tossed it for a reg dizzy
Old 02-05-2013, 08:01 AM
Resident Racing Jerk
vtec's Avatar
if i was building a 200mph car i wouldnt be running an opti. its just too easy to eliminate, consider how much money will be invested into the rest of the car.
Old 02-05-2013, 02:52 PM
BADMOON's Avatar
If I was building a 200 mph mile car it wouldnt be an LT1... But hey if your pockets are deep enough and its your mission. All power to him
Old 02-05-2013, 03:35 PM
fex77k's Avatar
I've wasted stock and aftermarket optis in just about every way you can, no need to run one if you don't have to.
Old 02-05-2013, 04:18 PM
9-Second Club
Ed Wright's Avatar
I agree. I don't miss having one at all. LOL
Old 02-06-2013, 10:36 AM
sweetbmxrider's Avatar
You're such a badass
Old 02-06-2013, 09:28 PM
fex77k's Avatar
I live my life a quarter mile at a time.
Old 02-07-2013, 09:14 AM
nitrous2fast's Avatar
Rumor has it, you'll die before going back?
Old 02-07-2013, 10:31 AM
Dude I almost had you!
Old 02-09-2013, 01:00 AM
BIGCAT7274's Avatar
run a lot of boost and keep the rpm reasonable and it can be done. you would want to change to a different ecm though.
Quick Reply: Opti Limits
