LS3 Fuel Pressure?
Old 02-05-2013, 07:43 PM
Gobs's Avatar
Question LS3 Fuel Pressure?
I am running the fuel lines in my 55 Chevy for my new LS3 crate engine 430hp. What should I set the fuel pressure at on the regulator?
Thank you.
Old 02-05-2013, 08:06 PM
WKMCD's Avatar
The LS3's in 08+ vettes run 58-60psi. I assume the F-bodies are the same.
Old 02-06-2013, 02:00 PM
LS1Tech Sponsor
Summitracing's Avatar
Received 1,121 Likes on 618 Posts
Chevrolet performance recommends a Fuel pump capable of 58PSI for their E-Rod LS3 430HP engine. WKMCD is correct and you should set your pressure between 58-60 psi.
__________________
800-230-3030
www.SummitRacing.com
Quick Reply: LS3 Fuel Pressure?
