opti rotor 180° off?
Hey everyone I had replaced Opti cap and rotor and was not paying attention to where the rotor was. My question is could I have put it on 180° off. The car is a 94 lt1
It's not like an SBC distributor that often gets put in 180° off. It could be off, but it could be in any degree if you did not orient the keyway properly. You don't need to know where the rotor is, just the keyway.
[edit] If it was just the cap and rotor (and you did not remove the opti), the rotor can only fit on correctly one way.
i did remove the whole opti now i am stumped. i have the car at tdc #1 on compression stroke. i have the opti out and took it apart again to see if i put it back wrong and i didnt. my question is how do i determan where to point this rotor at?
Last edited by teal94z281989; 02-06-2013 at 08:42 PM. Reason: sorry doesnt the key way only fit in one way on a 94?
Well if you have cylinder #1 at TDC correct me if I'm wrong but shouldn't you point the rotor at the #1 plug wire?
I've never replaced just the cap and rotor.
Thats how you do it on a distributor though.
idk im lost pls some one help. i thought the key way could go in one way on the 94 modles im stumped i have spark fuel and compresion but no start. when i brought motor to tdc #1 the rotor on the opti was pointing at about 8 o'clock
the 94 should be a spline drive opti, and it should only go on one way...but it can be forced if the splines are worn...I always make a mental note of which direction the rotor should be pointed from the location of the wide spline in the timing gear as I install the opti.
well did you check fuel fuel? make sure injectors are firing and such, also on cheaper optis the internal rotor can be off i have pics and i can show you what you mean. Had an issue like this also, bought an ebay opti because i was on a tight budget, put it on got one start with it.... after that it wouldn't work couldn't figure it out for the life of me ripped the whole engine apart checked the timing and and everything. finally i looked at my old opti and my "new" opti and i guess the bearing spun and the rotor was off like 25 degrees from were it should of been causing the car to sort of start but not really run....
The "new" one is incorrect. Are you sure the stub shaft in back is in the keyway correctly? It is keyed going into the opti, just like it is going into the cam gear.
Update she runs like butter now. Thanks everyone for the help. I feel stupid the no start was caused by me putting the spacer in first then the optical wheel causing a bind against the sensor but I swapped those two and she started up faster than ever lol thanks to the new 255lph pump
