WTT Twin Turbo 04 30k mile 1000WHP black coupe Cobra
Year: 2004
Make: Ford
Model: Mustang Cobra
Price: $32000
Mileage: 30150
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
Engine:
-Machine work and assembly by Pettis Performance
-Ford racing 4.6l aluminum block from Ford Racing catalog, stock bore, JE coated pistons/rings, 9:1 compression ARP head studs, ARP main studs, ARP 2000 rod bolts, 04 rods and crank.
-Comp stage 2 cams
-Comp beehive valve springs
-MMR Stage 3 ported heads
Turbo Kit: HP Performance Twin Kit
-Twin 61mm turbos
-Tial BOV upgrade
- Upgraded oil return pump
-Ported Mach 1 intake
- Intake spacer
-Ported Throttle Body
Fuel: Return style
-FORE dual Walbro hat
-Dual Walbro GSS342’s
- -8 feed/-6 return
-Aeromotive 40 micron filter
-Aeromotive regulator
-FORE Clear rails
-80lb injectors
Exhaust:
-HP down pipes
-custom 3" mid pipe with Magnaflow mufflers and dumped before axel
Trans
Freddy Brown 4r70 band new being installed right now best of the best no expense sparred 6k setup
-Manual valve body
-Trans brake
-circle d triple disk billet turbo converter brand new 5 year warranty
-B&M hammer shifter
-B&M trans cooler with fan and thermostat
Suspension:
Front:
-QA1 Tubular k member and a arms
-Strange coil overs
Rear:
-FRPP 8.8 SRA with moser axles, 3:73’s
-Welded axle tubes
-Team Z double adjustable uppers w/relocation brackets
-Team Z single adjustable lowers
-Team Z anti roll bar
-Strange 10 way adjustable shocks
-MM FLSFCs
MISC:
-MM 6pt powder coated black roll bar w/swing-outs
-Driveshaft safety loop
-AEM True boost Gauge
-Innovate LC-1 Wideband
-Reische 170 T-stat
-SCT Xcal 3
Car is sitting on stock 04 chrome rims 6k on the motor and trans 2k on the new turbos
You can look at my dyno threads car just made 703 hp 778 TQ on only 15 PSI Will make over 1000RWHP on full boost
Photos at http://s1248.beta.photobucket.com/user/Gt35mr/library/
Car is sitting on stock 04 chrome rims 8k on the motor Trans is brand new being put in right now just spent 6k and new FB Transmission setup 2k on the new turbos
