1996 f-body 4l60e into a 1995 chevy 1500
Old 02-08-2013, 06:49 PM
1995 T/A's Avatar
Default 1996 f-body 4l60e into a 1995 chevy 1500
Quick question- Anyone know what electronics needs to be switched to make this work? Aside from the speed sensor. I'm pretty sure the 3-2 down shift solenoid is different.
Old 02-08-2013, 07:33 PM
TSAEB's Avatar
I thought all that is needed is to repin the harness and u can use the vortec computer and dizzy. Not sure if u want to try and use the tbi stuff from your computer . If u look up vortec PCM on lt1 Motor u should find some really good post on this swap. I know one guy on this site that had great pics on how he put a 96-97 lt1 in his 97+ silveraldo.
Old 02-08-2013, 07:34 PM
nitrous2fast's Avatar
you got the swap wrong...
Old 02-08-2013, 07:42 PM
TSAEB's Avatar
Aww I see .. Well never mind .
Old 02-08-2013, 08:47 PM
flame's Avatar
The trans has the same electronics 95+
Old 02-08-2013, 09:10 PM
1995 T/A's Avatar
I know the 3-2 downshift solenoid is different in early 95's, it was changed mid model year. I suppose the solenoid could be switched if its different.
Old 02-09-2013, 09:33 AM
flame's Avatar
http://www.napaprolink.ca/PPSE/Buyer...tnumber=TCS552
This shows them being the same
Old 02-10-2013, 03:34 PM
8595transam's Avatar
The 95 4l60e was a one year only transmission. 96-97 were the same. You can swap a 96-97 trans. into a 95 by using the wiring harness from your 95 into the 96-97. The 95 3-2 shift has a different ohm reading then the 96-97. I talked to performabuit transmissions and this is what they told me to do. Currently putting a 97 4l60e into my 95 Trans am.
Quick Reply: 1996 f-body 4l60e into a 1995 chevy 1500
