Engine Reving Question
I have a 98 Z28 A4. It has recently started to rev up wildly on it own at random times. Sometimes i will start it up and it will idel fine and i will drive it a few miles then it will act like the throttle is stuck on it and want to idle up at 2000+ RPM. Other times i have started it and it will instantly idle up to 2000+ rpm. I have got out at that time and tried to manualy pull the throttle back and it is already fully back. Any ideas?
Thanks
Thanks
if the increase in RPM is only at idle I would first look at your MAF. The easiest way to check it out that i've done is by switching mine with a friends for a test. A dirty or failing MAF could cause the ECM to increase fuel raising the RPM at idol yet not be as big a problem as say a stuck cable while driving.
Increasing fuel ALONE will stall the engine if air is not increased along with it. Also spark needs to be increased to, or it will stumble and stall.
I agree about the MAF......easy to swap it with another one. But what a bad MAF does is make the IAC valve open and close....causing the increase in rpms.
Air going into an engine...EXTRA air from another source......is the only way an engine can rev up without the throttle blade being open.
