Summit 52mm TB or stock ported 52mm TB?
Old 02-09-2013, 08:50 AM
white3800camaro's Avatar
Default Summit 52mm TB or stock ported 52mm TB?
Which is a better piece?
The Summit one is lightly used, can be had for $100.
Or a stock one, ported and powdercoated?
I am not sure who does the best job on the stock units so suggestions would be great!
Old 02-09-2013, 12:18 PM
96capricemgr's Avatar
The aftermarket all offer IAC hassles so for 52mm I would always suggest a reworked stocker, one vendor can even sometimes get 54mm out of them.
I wouldn't bother with aftermarket unless doing 58mm.
Old 02-09-2013, 03:42 PM
MonmouthCtyLS7's Avatar
Why change it, if I could remember correctly back to my LT1 days the 48mm is just as good as a 52 or 58 unless your pushing some serious air...
Old 02-09-2013, 03:58 PM
both sides of that argument have been documented "in their favor".
That said it does warrant us asking him what is done to the car an a note about the A4 can be harmed y a larger TB if you don't compliment it with a tune or shift kit.
Old 02-10-2013, 06:21 PM
Just a basic rundown
LE 228/236
11.8:1 CR
All boltons
100 shot
3600 stall
built trans
dyno tune
Old 02-10-2013, 06:22 PM
Which vendor does them?
Old 02-10-2013, 10:00 PM
I bought a used 58mm BBK and dealt with the IAC hassles but I know I have seen 54mm advertized on ebay and that the vendor had a separate site too so some googling would turn it up.
Old 02-11-2013, 07:56 AM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Is the OEM throttle body 48mm?
Old 02-11-2013, 08:23 AM
bowtienut's Avatar
.Yes.
Old 02-11-2013, 08:56 AM
maxplusten's Avatar
I run a TPiS 58mm and so far no IAC issues so far, not sure if there 52 is the same story
Quick Reply: Summit 52mm TB or stock ported 52mm TB?
