Huron Speed Special Edition Kit w/ Turbo, WG, BOV, Oil Lines!
Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit
1 Kit IN STOCK, ready to ship, NO WAIT TIME!
Special Edition Features & Upgrades:
*ALUMINUM Cold Side Piping
*Pre-Drilled IAT Sensor Hole
*Included Hardware for Alt Relocation, Intercooler Brackets, and Turbo mounting
*Huron Speed T-Shirt
*Huron Speed Windshield Banner
*Huron Speed Small Sticker
*Turbonetics TC78 1.15 a/r Turbo
*Turbosmart Ultra-Gate 38 Wastegate
*XSPower 50mm BOV
*Oil Feed line with fittings
*Oil Drain line with fittings and flange
Pricing on this ONE, IN-STOCK, COMPLETE special edition kit is $2999.99. Don't miss out on this special price, as only ONE is available!
You can view on our website at:
http://shop.huronspeedproducts.com/F...FBodyTurbo.htm
*ONE of these in stock, get it while it's available!*
**We can upgrade the turbo to a new T-series unit with the 75mm turbine wheel no problem at an additional charge. If you want to switch out some components, simply shoot me a PM for a custom quote!!!**
-This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, oil-lines, etc as you can see from the picture!
-Hot Side piping is made from 321 Stainless, yes 321, and polished!
-Cold Side piping is made from Aluminum which is a special feature in this special edition kit which saves you 9 lbs from just the material change on the cold side!
Components:
-Turbonetics TC78 Turbocharger with a 1.15 a/r housing. Carries a 1-year warranty from Turbonetics!
-Turbosmart Ultra-Gate 38 Wastegate
-XSPower 50mm BOV
-2.5" crossover with T4 flange and 38mm Wastegate Flange, dump to atmosphere
-3" Downpipe with 3" V-Band flange (3" V-band on exhaust end also for easy to add on more exhaust)
-3" ALUMINUM Cold side piping from turbo to FMIC to Throttle Body (9# weight savings)
-50mm Blow-Off Valve Flange on Cold side piping
-Pre-Drilled hole for IAT sensor on Cold side pipe
-Oil feed line with fittings
-Oil drain line with fittings and flange for off the turbo
-4" core front mount Intercooler
-All exact, specific couplers
-All exact, specific T-Bolt clamps
-F-body front mount intercoolers brackets
-F-body alternator relocation brackets
-Hardware to mount your Alternator Relocation kit, intercooler brackets, and turbocharger!
-Huron Speed Boost Gauge T-Shirt (Small-3XL)
-Huron Speed Windshield Banner
-Huron Speed Small Sticker
Hotside piping made from 321 stainless steel, fully polished.
Coldside piping made from aluminum, can be polished if requested
Requires Pusher Fans, Misc Hardware, and Truck Manifolds to complete
Kit requires removal of the A/C, Low Oil Sensor, and lowering or removal of front sway bar
*XSPower 50mm BOV
Components:
-XSPower 50mm BOV
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Only one available!
__________________
I will toss in 2 cans of Chicken Noddle!
__________________
Awesome, keep your eyes pealed!
__________________
Sold! Anyone else looking for a similar set-up, shoot me a PM!
__________________
