help me hook up my jgs bov and wastegate please
Old 02-09-2013, 06:07 PM
mrstepheneades's Avatar
Default help me hook up my jgs bov and wastegate please
Hey guys. I have a jgs 56mm bov and 50mm wastegate. Need someone to explain where i need to plumb the hoses.
The wg and bov have two threaded holes on side. One toward the top and one closer to base. Can anyone give me a detail explanation off where what goes? I do not have boost controller. Just using spring in wg..
Thanks
Old 02-09-2013, 07:55 PM
dammarler's Avatar
On bov, tap into a vaccum source from the intake behind throttle body
On wastegate, vent top port to atmosphere and you can use the same vaccum source as your bov for bottom port
I used the vaccum hose off the driver side of the intake behind the throttle body for both to work from and have had no issues
Old 02-09-2013, 08:12 PM
So hook top port of bov and bottom port of wg to a port somewhere behind throttle body. And thats all i gotta hook up? To be good to go.? I know the other port in wg is probably for boost controller but what is other port in bov for.?
Old 02-10-2013, 07:47 AM
Old Geezer's Avatar
Google and WALA!!
http://www.jgstools.com/turbo/wgpg.html
Quick Reply: help me hook up my jgs bov and wastegate please
