93 Cobra Clone 6.0 408 Stroker, 4l80e, S480R Turbo Build.
Old 02-09-2013, 08:20 PM
zapp109's Avatar
Thumbs up 93 Cobra Clone 6.0 408 Stroker, 4l80e, S480R Turbo Build. IT LIVES!! video
EDIT 2-17-14 Last page for video
Updated list and parts Also found out my LQ4 was total **** that I got so I decided to put a 408 Stroker inside my 6.0 block.
Well figured id start my build thread.. going to be a while before the car is done but everyday i work on it from here on out im going to put a update.
So I got this car last year with a 408w, and built Gforce trans. I had to complete the cobra look by getting a few items. I wanted a real cobra but i figured why get a real one pay 10K and chop it up. Instead pay 5K and sell all the parts for 5K This car is supposed to be my hotrod that i can cruise 200 miles and go to track with.
Ive been collecting parts for over a year now and here is what i have so far
S480R turbo
6.0 Iron block
truck manifolds
317 Heads w/ valve job
408 Stroker with Scat rods, eagle crank, still getting the details from my engine builder. 9:2:1 compression
Vic Jr manifold with rails
Low profile elbow
90MM wilson TB
EV6 95# injectors
Aeromotive eliminator pump
Comp Cam
ls2 timing chain
trickflow pushrods
ls7 lifters
patriot gold springs
Melling oil pump
Harland Sharp 1.7 rockers
50MM Tial BOV
Precision 46MM Wastegate
Snow stage 2 meth kit w/progressive controller
AEM wideband
AEM TruBoost controller
Unknown 3" inlet 4" thick intercooler
Circle D Multidisk converter with flexplate
I have a built 4l80e on the way hopefully have it in the next week or 2. Full manual with trans brake. (still waiting on my trans)
Mustang parts-
Moser 31 spline axles with c clip eliminators
Moser Wavetrac diff
Moser yoke
Moser Diff cover
AJE K member with A arms
Strange front coil struts (adjustable) w/200lb springs
rear strange shocks (adjustable) and coilovers in stock location 175lb springs
TeamZ street beast rear kit with anti roll bar
03-04 Cobra brakes for front and rear w/sn95 spindles
93 cobra master cylinder
flaming river rack (manual) and UPR bump steer kit
Things to get-
turbo piping
PSI harness with computer
shifter for 4l80e
gauges
driveshaft
Wheels, i have 5 lug PonyRs on order that are 17X10 in rear and 17X6.5 i think in front. But after i get them i am going to get the fronts narrowed to 17X5
Here are some of the engine parts with the old turbo, these were going to go in a WS6 as you can see the 98 gas tank
So here is the progress so far..
Old 02-10-2013, 10:08 AM
MIKE93SVT's Avatar
looks good so far
Old 02-10-2013, 02:42 PM
LS1PUNK's Avatar
Looks good, shouldnt be too long considering u have ALOT of parts already.
Old 02-10-2013, 03:10 PM
zapp109's Avatar
Hopefully not to long, this week im picking my shortblock up from my dads garage and hopefully dropping it off at builder to get assembled.
here is what got done today
Tomorrow will be pull out gas tank and fuel lines.. then clean up underside to get ready for undercoating.
Old 02-10-2013, 04:30 PM
LSx '85 C10's Avatar
That's gonna be one BASA$$ Fox!!
Old 02-10-2013, 05:32 PM
pmgm's Avatar
Looks like a nice build.....
Old 02-17-2013, 02:28 PM
zapp109's Avatar
Not much to update, did some undercoating and painting. Painted K member and A arms. Also SN95 spindles. Installed K member. Also bought a aeromotive eliminator pump just to be safe since im looking for big power. A1000 will be for sale.
Old 02-17-2013, 03:30 PM
stangtrader's Avatar
Nice clean fox,this is gonna be a awesome swap
Old 03-01-2013, 03:40 PM
zapp109's Avatar
Not much to update, but my qa1 coilovers did not work with sn95 spindles so i sold them to my buddy and got some strange adjustables.. Learned that the drivers side cobra calipers take bigger bolts then the passenger ... WTF so i had to go buy bolts to fit it, then had to make the spindle holes bigger for the bigger bolts... and thats a real bitch just using small drill bits. Sooooo next step is to get my flaming river rack and get the rear parts.. My goal is to get this thing to be a roller then start the engine trans stuff.
Old 03-07-2013, 05:23 PM
zapp109's Avatar
Im out of town but my wife sent me this picture of what showed up today..
bullseye S480R
Old 03-14-2013, 04:08 PM
zapp109's Avatar
Well well well... lets say my motor plans have changed. It looks like im getting a 408 stroker ... Ill have details soon.. Motor is at shop and the block was shitty and the crank was shitty so i said what the hell and told him to get me eagle crank. So in about 2 weeks ill have my 408 stroker boost motor Also in 2 weeks i should have my built trans and circle D multi disk converter. Tomorrow my Moser parts should be here. Wavetrac diff, 31 spline axles, c clip eliminators.
But this showed up yesterday
3" mandrel bend exhaust tail pipes ..
Old 03-15-2013, 03:33 PM
zapp109's Avatar
rear parts
Old 03-16-2013, 09:38 AM
booboo37's Avatar
Who`s 3 inch tail pipes and how much where they ?
Old 03-16-2013, 04:06 PM
zapp109's Avatar
They are VRS tail pipes, i got them off corral forum group buy section.
280 dollars shipped i think is what i paid
Old 03-17-2013, 04:07 PM
zapp109's Avatar
Welded my axle tubes and a shock support on the side it wasnt welded. Yes i know not pretty welds it was tough with my welder and how dirty it was.
Old 03-18-2013, 07:01 PM
booboo37's Avatar
Thank you for the info on the tail pipes......i now have the itch...
Old 03-20-2013, 05:48 PM
zapp109's Avatar
Flaming river rack showed up today
After some customizing, had to chop off the tubes they had on the aje K member. They were to big to go through the new flaming river bushings. So i chopped them off and ran some grade 8 bolts.
Old 03-20-2013, 08:44 PM
6D9 Matt's Avatar
Damn this is nice. I LOVE the look of a 93 Cobra, and with an LS?
Very nice man. Very nice.
Old 03-21-2013, 06:23 AM
Sarg's Avatar
Very similar to my build but with an extra 83 CI have you been hearing good things about the wavetrac? That is the one part about my build I am still unsure about. I have been back and forth between a locker and a spool. Also what are you doing to eliminate the c-clips and retain rear disc brakes?
Old 03-21-2013, 04:21 PM
zapp109's Avatar
Sarg, not much info on wavetrac but moser told me i break it they will send me a new one so thats all i need to hear. This is a street car so i absolutely dont want to spool it. I talked to a tech at race proven motorsports and he said they have put a few in some high HP cars no issues. I got the "03 cobra" wavetrac it has no c clip slots. Im running 31 spline axles with moser c clip eliminators. I got the moser axles that are meant for disk brakes. To run the disk brakes and retain proper offset I did this. Or should say im in the middle of doing it.
http://forums.corral.net/forums/8559832-post138.html
Quick Reply: 93 Cobra Clone 6.0 408 Stroker, 4l80e, S480R Turbo Build.
