402 LS2 Stroker long block
Category: Engine - Complete Motors
Price: $4500
Location (State): AZ
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
This motor was properly broken in with rotela motor oil and has never been sprayed.
The reason I am selling is because my 4 year old labrador needs knee surgery.
LS2 Aluminum Block
Eagle 4.00in Stroke Crankshaft w/ 24 tooth reluctor
Callies Comp Star connecting rods
Wiseco Forged pistons 4.005" bore x 4.000 stroke
6.125" rod length -8cc Dish w/ steel top/napier second ring set
Clevite main & rod bearings
ARP Main studs, ARP Head Studs, ARP rod bolts
LS6 Ported oil pump
Comp Double roller timing chain
243 casting ls6 heads
MS3 Cam on 113 LSA
Comp lifters
Comp Hardened 7.4 pushrods
PRC dual valve springs w/ titanium retainers
All machine work was done by Standard Machine in Glendale, AZ. The Engine was also assembled by them. I have paperwork for the rotating assembly and machine work.
This setup made 445 hp/ 428tq with stock 243's and ls6 intake.
I will try to post a video/ pics of the engine itself when I get a chance.
Willing to ship, send your zip code and ill try to get an accurate quote
Alex
