Another SBE LS1 on 200-250hp n2o timing?
Old 02-10-2013, 05:04 PM
T/ALT1's Avatar
Default Another SBE LS1 on 200-250hp n2o timing?
Putting together my first LS1, it's SBE with rod bolts, TSP 233/239 598/600 112ls cam. Ported stock castings with Brian Tooleys 660 lift spring kit, LS6 oilpump, Ls2 timing chain, LS6 Intake, ported stock T.B, SD tune, 1-7/8" headers, 3" true duals, Th400/ 4k PI converter, Fab 9" rear, 3.73's, 275'sRadials, 3100lb raceweight. The car is a 95 Transam that ran 9.80's with my old LT1 on n20 so I'm hoping to run 9.50's or quicker with this setup. I'm going to start with Br7's and 6 degrees of timing pulled and just going to add n20, pull timing and fuel until I get the plugs looking good. What do you guys think of this setup and do I need a stand alone fuel system? I plan on running whatever fuel is needed for the amount of n20 being used. I am going to run dual 255 fuel pumps and alky injection for safety.
Old 02-10-2013, 05:30 PM
James@ShorTuning's Avatar
6deg not enough for that shot. These motors are completely different than the old small blocks. Pull 2* per 25hp on these and work your way back up...
You'll need an 8 or 9 plug at least with good gas too
Old 02-10-2013, 05:57 PM
T/ALT1's Avatar
Well I was going to run 110 octane to start tuning the 150 shot but I'll take any advice I can get to start tuning the n20. I read where Cam was pulling 14 degrees on 250hp so I was going off that too. So I need to pull 12 degrees on 150hp n2o?
Old 02-10-2013, 08:02 PM
Really depends on where your NA timing comes to. I was pulling 12.5-13 on a 175 in my car. That ended up at 16.5* after it was pulled from my NA timing. Had a nice clear timing mark and I was on C16.
Old 02-10-2013, 08:14 PM
T/ALT1's Avatar
Yeah we'll that makes sense b/c your total timing was almost 30degrees. I was thinking like 26 degrees On motor then pulling it down to 20degrees to start tuning on 150hp. But the last thing I want to do is have any detonation on these factory pistons so I'll probably start at 17-18degrees. Thanks
Old 02-10-2013, 09:48 PM
boostit5.3's Avatar
im at 29 degrees on motor and 23 on a 200 shot.. its a 99 5.3 though.
Old 02-10-2013, 09:50 PM
boostit5.3's Avatar
every car is different though i've always pulled 2 degrees per 50 to start with. if your going to that big of a shot you might as well throw in some 8 plugs.
Old 02-11-2013, 12:40 AM
camscam02's Avatar
Start at 17 degrees on a 62 jet and go from there, better safe than sorry, the plugs will tell you what the motor wants
Quick Reply: Another SBE LS1 on 200-250hp n2o timing?
