Spec Twin Disc in 04 CTSV Clutch Shim Question
I have the Spec Twin Disc in my CTSV and I don't think I have the correct Shim package from Spec. The adapter is about an 1.5 in and per measurement it looks like I need more like .5 inch. I had called spec and with out a pic they say its correct. I measured from where the trans hits the flywheel cover and compressed slightly the slave and its a little over 1.6". Then measured from flywheel cover to the fingers and its more like 2.1". Ideas?
I know I will try and call spec and find out the problem.
Spec CTS-V Super Twin 2-Disc SS-Trim (2004-07) (SC66SST-2)
