Unlocking issue
Old 02-11-2013, 12:36 AM
TooBerserk's Avatar
Default Unlocking issue
I have a 99 TA. My doors are able to lock with the button on both doors, but when you push to unlock, all you hear is a noise and the doors won't unlock. Anything to help fix it?
Old 02-11-2013, 01:28 AM
SparkyJJO's Avatar
What kind of noise
Old 02-11-2013, 12:23 PM
TooBerserk's Avatar
Just like a clicking noise. Sounds comes from both doors, but the door won't unlock
Old 02-11-2013, 12:24 PM
TooBerserk's Avatar
I've been told To clean the connectors or the actuator for the door is out
Old 02-11-2013, 12:40 PM
SparkyJJO's Avatar
Could be, but both at the same time sounds fishy. If you put light pressure on the lock lever like you're going to manually unlock the door and hit the unlock button, does it then unlock or still just click?
I had a door lock problem on my 98 and it was the relay in the BCM that triggered the locks. I work on circuit boards so I simply replaced the relays, but I know most people probably won't want to do that kind of thing or have the tools or know-how.
Quick Reply: Unlocking issue
