Category: Accessories
Price: $475
Part Fits: 2010+ Camaro
Location (State): OH
Item Condition: Brand New
LS Engine?: Fits LS Engine
I'm selling a set of Custom Billet Valve Covers.
Our tall height range of LS Series engine valve covers are designed with the high performance street & outright race engine in mind. The main advantage of our tall series LS rocker cover is its ability to fit over most types of aftermarket rocker-gear without the use of a spacer. Other benefits include factory style baffled breathers and enough material at the front and the back of the covers to add -8 fittings for race style breather systems.
Factory style baffled breather
Front and rear bosses for adding larger breather fittings
Integral bosses for mounting ignition coils directly to cover
O-ring seal to cylinder head
CNC machined oil cap with o-ring seal
Adequate clearance for most aftermarket rocker gear
They were on the car for dyno-testing only.
They are made by Noonan Race Engineering.
http://www.noonanraceengineering.com...bcategoryID=29
They can also be seen here:
http://granatellimotorsports.com/pro...nts-561-0.html
They do not include the coil covers, but you can get those from Granatelli Racing.
Although I am not selling the coilcovers, here are a few pictures with them on the valve covers.
I took this one when they were assembling the engine. Only 2 of the coil packs are on this side.
I'm asking $475 plus $25 shipping (to continental US addresses), as is.
The coil packs in that picture are from a 2010 Camaro.
I asked the tech at my shop and he said those valve covers will fit many different heads. You might try calling Granatelli (the link is in the first post) and ask them if the coil covers they sell for these valve covers will work with your car. (I am not selling the coil covers with the valve covers as it says in my first post.)
I can also ask the tech at my shop tomorrow or give you his contact info and you can ask him.
Edit: I went to Granatelli's site and I believe that either of these coil covers will work with these valve covers with your LS1 coilpacks.
http://granatellimotorsports.com/pro...et-1396-0.html
http://granatellimotorsports.com/pro...et-1400-0.html
But, you should call Granatelli to confirm this.
Thanks... you can have one just like it! Start with these valve covers and then you can also buy the intake manifold here: https://ls1tech.com/forums/parts-cla...-manifold.html
