Better handling
Better handling
What type of performance feel can I expect to see from Strano's hollow front and rear sway bars? Car is a 2001 WS6 with 13k miles. It already has Strano springs and Koni 4/4.
I need an adjustable PHB too. Preferable on car adjustable. Which one Will do the trick since there are like 12 options with different ends???
Any other recommendation to make it handle better? I just bought Michelin Pilot Super Sports so that should help too.
Thanks,
Thanks,
Wow. Nice car and combo.
For the PHB, you can use poly poly if you like things quiet. As you move closer to rod end rod end, you gain an increase in performance due to reduced deflection with a minor increase in road noise.
-- Ramey
-- Ramey
Yes, already have the SLP subframes. Nice and heavy, lol, but they bolted on in 3 point as I did not want to permenantly alter the car with welding.
I have seen bits and pieces on that and very intrigued on what they did. I caught it after the mods though so I haven't been able to find early articles yet. I am ordering Forgelines in the next couple weeks so those additional front end mods will need to wait until later in the year. Which is fine as it gives me time to research. Do you have links to the articles by any chance?
I have strano springs with bilsteins on my z28 and it made a big difference. I'm waiting on some strano sway bars that I ordered a couple days ago, they should be here any day. Cant wait to see how the car handles after the strano sway bars.
Ramey,
Are there any downsides to this PHB with a single rod end and poly on the other side? Will this contribute to road noise ect...??? What is the difference with the roto end for a few dollars more?
http://www.stranoparts.com/partdetai...D=70&ModelID=8
I did Konis first, then the strano front bar, then the rear bar then his springs in that order, so i can't tell you exactly the change you will feel since you already have his springs, but Ill tell you what I would expect. They should feel very similar to the difference you noticed from the springs, minus the change in ride quality. The car will be even flatter in corners, have less all around body movement/roll, and an increase in grip, higher cornering limits while being balanced about the same as now.
Thanks,
Thanks,
That and what you have now will make the biggest positive change in handling, everything else is minor.
Ramey,
With the PHB it's all good since the PHB pivots around the bolts and doesn't have to articulate (much).
Thanks,
Thanks,
Thanks,
Thanks,
Yes there was a big improvement going to the Watt's from PHB. The car is much more balanced. The car reacts the same turning left or right. The car doesn't oversteer like it did. You can change the roll center with the Fays2 of the car for more/less oversteer/understeer.
If you call and order from Strano he can give you tips with the install. The wattslink needs to be installed properly for it to work properly.
